Hello there,
I'm building a low cost mmicrophone, using an electret capsule. I intend to use Schoeps style circuit, similiar to the Alice mike. Here's the schematic:
I plan to also include 2 22pF caps paralel to the 100K resistors. Also, I changed the leftmost cap to 100uF. The trannies used are going to be 5087 in smd package.
I have some questions:
1) Where the two 100K resistors connect togheter, in some designs (e.g. Alice Mic) it's added a 6K8 resistor from there to the 12V rail. As I understand, it is used to limit the current provided by phantom power. Yet, it seems like most phantom powering devices include this resistor internally. So, should I include it in the circuit or not?
2) The two biasing resistors are usually 2K2 Ohms, yet, some designs show different, higher values, like 5K6 (in both cases it is used a 2K2 Out Impedence capsule). What value should I use for a 2K2 IMpedance, 9.7mm capsule?
3) There are two variants of the capsule I intend to use. One has a -46dB sensistivity and the other -36dB, if I''m not mistaken. I'm going to be using the mic mainly for dialog and ambient sound recording (for films) and, ocasionally, music recording (as ambient mics, also for films). What would be the best fit?
It would be most helpful if you could answer these quesitons.
JDias
P.S. If there is interest in these mikes, once they're finished I'll post some photos, and the BOM and board if anyone desires to build them.
JDias
