DIY benefit tube sale
I started checking out DIY audio, because I wanted to build a set of speakers. While waiting for components, I started building amps of various sorts. My amp building days are done - got more than I need. Along the way I accumulated extra stuff I didn't get around to using, or have more than I need for a long time. So out it goes, starting with tubes. I've enjoyed this forum and learned a great deal here. The benefit part is that you make a contribution to DIY instead of payment to me. Give me proof of the contribution and I'll send you the stuff. I'll pick up shipping, but only to a U.S. address.
First come first served. Prices are for each lot. As far as I know they all work.
JJ EL34 Quad, New, $25
Sylvania 5U4GB, 2 NOS, and one used VT244 (works but center locator pin is missing), $25
Servicemaster 6JC6A, 5 NOS, RCA 6AU6A 2 NOS, $15
Magnavox 6CG7, 2 NOS, RCA 7F7, 1NOS, Sylvania 7N7, 1NOS, $15
GE 6SN7GTB, 1 NOS, 1 6H8C, New, $50
GE 5687, 2 NOS, 6 Dumont 12B4, $15
Various 12B7, 5 NOS, 1 Used, $15
Sheldon
I'll take the Quad of JJ EL34's.........I just donated the $25........Sheldon, I'll send you a PM with proof (hopefully...)
Done. List is now:
Thanks for the nice words az, and you are welcome Cal,
Sheldon
Current remaining
Still have these:
Also for the tube folks, some HV electrolytics, some used, all recent vintage, all measure good:
47uf, 500V, 2 JJ, 1 Panasonic UP (new)
47uf, 450V, 4 Nichicon vx axial (used)
100uf 350V, 17 Xicon (some new, most used), 8 Panasonic ED (new)
The lot for $20
Motor Runs:
2uF, 440VAC, 4 Mallory oval
4uF, 370VAC, 2 Mallory oval
6.5uF, (voltage unknown, but I have one on a 600V supply), Bendix cube
20uF, 450VAC, 2 Siemans round
30uF, 330VAC, 1 Sprague round
The lot for $15
Will be adding film caps and other stuff in the next couple of days.
Sheldon
Russian Teflons
And some film caps:
0.1uF teflon, 10 Russian T-3, 600V, 2 Russian K-7, 500V
0.22uF film and foil, 6 Russian K-75, 500V
1.5uF polyester film, 4 National Capacitor, 400V, 2 RIFA radial film, 400V
2.2uF, radial film, 2 RIFA 400V, 2 RIFA
10uF, Paper, Russian M6RO 300VAC
$15 for the lot.
And some Iron:
Electraprint:
Output: 12k PP or Parafeed (good for about 5W), 2 pairs. $20/pair
Power transformer: 960V CT/60mA, 6.3V/3A, 6.3V/1A, 7V/3A, $20
Autoformer: PSA 2N, $10
Stancor Filament 12.6V CT/3A, Hammond Output, 125-C, Choke, 156-R (1.5H, 200Ma), Choke 153-L (0.9H, 75mA) $15 the lot.
I'll take this lot of tubes, <Magnavox 6CG7, 2 NOS, RCA 7F7, 1NOS, Sylvania 7N7, 1NOS, $15> and <Stancor Filament 12.6V CT/3A, Hammond Output, 125-C, Choke, 156-R (1.5H, 200Ma), Choke 153-L (0.9H, 75mA) $15 the lot.>
PayPal to Canada -- i was going to say tuck them in with Maxro's but looks like he has moved up island (still might be cheaper to try to get his & mine in the same box, and i can forward from here -- Max?)
Will probably take the $27 (?) flate rate box.
dave
Not yet spoken for:
The lot for $20
And some Iron:
Electraprint: Output: 12k PP or Parafeed (good for about 5W), 1 pair. $20
(I used this set to make a resistor loaded parafeed 801 amp. Very nice sound.
Autoformer/phase splitter: PSA 2N, $10
dave
Looks like the most economical way. PM an address, and I'll get it out.
Sheldon
