Nwavguy did a good job on the O-* family of products, but he kinda looses...objective marks when he suggests he has reached some kind of performance sweet-spot where anything worse is a "compromise" and anything better is "needlessly good".
This is precisely the crux of the matter. If you go down the road of "good enough" then there's absolutely no need to stop at the O2. Pretty much anything will do the trick. Just use your headphone output on your laptop or MP3 player and stop wasting your time on here
Tangible proof of what the human ear is capable of hearing is obtainable, you just haven't taken the trouble to obtain it.
No... this is absolutely not true. I don't think you properly understand how these tests are run. I've participated in them, and been involved in the crunching of data, and I can assure you that the results are
not scientific proof. They are at best a vague estimation of what the general public is capable of hearing and that's not a legitimate test as far as I'm concerned.
Let's consider an anecdote for fun:
I task you with telling me how fast a human can possibly run 100m. As a response, you gather 50 random people you find on the street, get them to run 100m, and report back that the fastest a human can run 100m is 13.8 seconds. Do you think that's true? Let's say I tell you to try harder, and instead of 50 random people, you collect 50 pretty solid athletes. Now your result is 11.1 seconds. Is that true? let's say you're even more clever, and you tell me that the fastest man on earth is Usain Bolt and he can do it in 9.58 seconds. Can you say with 100% certainty that he is the fastest man on the face of the planet? Maybe he's just the fastest man we know about to date.
The problem with people making claims about A/B testing is that it's just like the first part of my example above, except instead of 50 people you have more like 2 or maybe 6. That's not a big enough cross section to draw a scientifically significant conclusion, and it's certainly not enough data to make a wild claim like "nobody can hear the difference between an O2 and a Benchmark". It may have been true for the two or three people in the test, but that doesn't make it a universal truth, or a scientific fact.
@opc: So do you hear a difference between the wire and the o2 in a blind, level-matched comparison, if so what do you hear, what do you think it is in the measurements and what headphones did you use?
With my Denon AH-D2000 phones the answer is no... I cannot tell them apart reliably in an AB test.
With my HE-6 phones, I can reliably tell them apart at higher levels. The Wire is significantly better at higher output levels, especially in the lower registers.
Would I make the statement that nobody can tell them apart based on the above? No... that's very presumptuous.
Back to the main topic... the OP asked if there was an amplifier available with superior measured specifications to the O2, and indeed, there is. Perhaps he wants to listen to both and draw his own conclusions about what he feels is "good enough" for him. After all, it will be different for everyone.
I suggest everyone here try the same thing and decide for yourself. That's why we're on here to begin with isn't it?
Owen
