I've been modeling a diode hard limiter as part of a circuit that I describe in another thread:
http://www.diyaudio.com/forums/subwoofers/229141-lt-gain-dependent-boost-limiter-new-idea.html
The diode limiter is a last resort stopgap in case the other circuit is implementing a "soft" response and the user wants to prevent excess voltage being sent on down to the amplifier.
The problem with hard limiting that uses diode clipping is that the clipping squares off the tops of the waveform, and that introduces lots of harmonics as distortion products. While looking into this kind of thing recently, I happened to stumble upon a technique that uses a differential amp to compare the signal before and after clipping. The output from the differential amp represents the "error" e.g. the induced distortion. This in fed back out of phase to the clipped signal to cancel the distortion components.
The circuit is briefly described in the text below Figure 11 near the bottom of this web page:
Limiters & clipers
In the description the differential signal is low-pass filtered, but it seems that the distortion from a squared-off waveform will be mostly made of up higher frequencies. It's not clear to me why the LP filtering is needed/used, but I haven't modeled it and maybe that would become readily apparent.
Does anyone have experience with this approach? How effective is it in practice?
-Charlie
Limiters & clipers
-Charlie
That circuit does the opposite of what you want: it undoes the clipping (by adding back the removed LF signal), but retains the distortion!
I would treat that web page with some caution. It appears to claim (under fig 3) that germanium diodes clip with more even-order distortion. Not true: any balanced clipper will produce only odd-order distortion whatever type of diode is used. An unbalanced clipper will add even-order too, whatever type of diode is used.
I wonder if the filter type is incorrect, and it should be a HP filter. That would make much more sense to me...
soft limiting means that the compression distortion starts at a lower signal level
maybe it is acceptable in some situations - like when for some reason you simply can't have the required headroom
but if you just want a simple analog clipper to prevent amplifier output stage clipping recovery issues then you still have the option of using enough power, high enough speaker sensitivity to keep the clipper from being audibly obnoxious
Self, Cordell appear to actually want to reduce lower level distortion vs a simple diode clipper with their input signal clipper circuits - which means "sharpening" the clipping characteristic
Geddes may go the other way - doesn't worry much about high SPL distortion in loudspeakers - so presumably not in amps either
Using a higher amplifier power is not really an option in this case. This is for a Linkwitz Transform type application, with high levels of boost (e.g. 24+dB) already applied to the lowest bass using very high power levels (e.g. 500-1000W).
-Charlie
An HP filter in the side chain would make more sense, but their write-up and diagram agree that it is LP. Never easy to tell from one article whether someone doesn't understand, or just bad at explaining, or temporarily confused.
