I am a newbie at speaker construction, and I was thinking about starting with a sealed sub. I noticed that quite a few people go for Shiva designs, and I went to adire audio's web site and red the sealed design white paper.
I also ran some equations to see what I could come up with on my own. I noticed some striking differences in what the equations say and what Adire Audio says.
I was looking for a Qtc of around 0.6. Using a spreadsheet I found on diysubwoofers.org, I plugged in the T/S parameters for the Shiva, and calculated for a Qtc of 0.6. I compared the numbers to the Shiva white paper, and here is what I saw:
______________White Paper: _____ My calculations:
Box Volume:___88.5 liters ______ 110 liters
Anechonic F3:_30.7 Hz __________ 39.1 Hz
Anechonic F8:_20.5 Hz __________ 23 Hz
Fb:___________34.4 Hz __________ 32.3 Hz
I realize that the box volume difference is due to the use of stuffing in the white paper's designs. I thought that stuffing simply increased the apparant box size to the driver (hence the ~25% difference). Can stuffing alter the other results this much? Or is Adire fudging on their numbers?
