Discrepancy between REW measurements and SPL measurements
Writing in for a friend...
Four loudspeakers of identical make and model were tested under identical circumstances... The disparities in their response was only to be expected (+/- 4 dB or so < 8 KHz?), given that they are not high end drivers meant for any audiophile purpose... Please see REW graph below...
However the SPL readings when running program material and pink or white noise, show a 12 dB discrepancy between the drivers.
How can the over all output show a 12 dB discrepancy when the frequency response seems to show a +/- 4 dB discrepancy?
A question: when measuring freq response, did you equalize the drive levels to get the curves to overlap?
The other thing is the location. Did you move each one into the same position for the SPL measurements, not changing the mic position, while in the next test they were in a different location?
Jan
