Is there any substitute that you know?
As has been mentioned before in this forum: 2SK370 / 2SJ108 - seemingly the same chip in a different package. Unless they become obsolete too.
Ruach said:I was recently informed by Toshiba that the 2SJ74 JFET will be discontinued this year. There will not be a replacement.
My supplier has also unofficially hinted that the 2SK170 may be discontinued by next year.
FYI
So what was the last date code of the genuine article ?
No doubt they will be faked!!
Except for 400mW max power dissipation for 2SK170 compared to 200mW for 2SK370, I can not see other difference at first sight.
So why the 2SK170 is obsolete and not the 2SK370?
This is all old news, but for whatever reason it catches fire again from time to time.
There are no Toshiba low noise P-ch JFETs in production.
The 2SK170 is current through some time this spring--I forget the exact date. The 2SK389 has been gone for quite some time.
There is product in the retail pipeline, so you will be able to buy parts for a while yet.
As for why, I've not seen any formal reasons from Toshiba, but my working hypothesis is that they regard through-hole parts as obsolete and are eliminating all through-hole parts from their catalog. The answer to your next question is no...I do not know of any plans to produce surface mount low noise JFETs in the near future.
Try to be rational about this. I've seen people who won't use ten parts in their entire lifetime talking about buying a hundred, "Just in case!" Just in case of what? Martians land next door and demand that the DIYer build them a fratzenwhoosis so they can call home? Rather than panic and start hording parts you will never use, sit down and make a list of the things you might actually build and buy accordingly.
Grey
Grey
Because you can now make the same transistor on half the die size with advanced lithographic processes, and hence twice the number of transistors per wafer, and hence half the cost / die. The penalty -- half the dissipation because of reduced die area for heat transfer. But I guess the transistor still sells for the same price, and most people could do with 200mW. So it makes sense for Toshiba.
And as far as I know, 2SJ108 is active.
Patrick
Patrick
- Discontinuation of 2SJ74 and 2SK170
