THE RAIL CAPS VENTED IN THIS AMP..
THE ORGINALS ARE 3300UF 75WV
WILL IT BE OK IF I SWITCH THEM OUT TO 2200UF 80UF OR WILL THAT CAUSE PROBLEMS ??
It will probably be OK if the original value isn't available but you need to test it thoroughly by running it hard for at least an hour into its lowest rated load to confirm that they will be OK. If possible, get low ESR, 105C caps.
