Well I've been reading about the advantages to a dipole setup (though I've never heard one to compare)
I plan to purchase a cheap cheap pair of pro audio 12" to make a "test" subwoofer to see if I like Dipole sound
I would, however, like for someone to give me a link to a dipole midbass solution
if it works out and it sounds like everyone boasts, I might make a 8-10 speaker bass array with 10" drivers....
but I've been reading and there are certian baffle design problems with a midbass dipole solution. any calculators or programs to help me figure it out would be appreciated
also is there any set distance between the dipoled woofers and each other?
What's the difference between W-shaped and H-shaped?
I believe H-shaped will not allow for use up to 300 hz like the midbasses would play... so I dunno what I need to accomplish this...
