i've been wondering what kind of application i can come up with for this woofer:
21" Beyma
and i figured it out - dipole !
but not a subwoofer, just woofer ... it would probably be able to handle stuff down to about 60hz and below that frequency a subwoofer would take over.
basically i think this driver would be excellent to cover the region where all the mud from room modes is - 60 to 200 hz or so.
i also thought of a way to pack four of these drivers into a reasonable sized dipole "box" ... it would be like a pyramid inside of a box missing front and back. two drivers would face forward and two back to cancel motor distortions. i could maybe draw a sketch sometime if necessary.
above 200hz there arent any serious anomalies with room response and below 60hz you will not find most of the musical instruments like voice, etc so some accuracy can be sacrificed there
what do you think ?
21" Beyma
what do you think ?
and then at the center of the pyramid you could place a (sealed back) 12" mirange or so. the thing would then double up as a horn for the midrange and form a concentric array.
vasyachkin said:and then at the center of the pyramid you could place a (sealed back) 12" mirange or so. the thing would then double up as a horn for the midrange and form a concentric array.
I think the bass drivers will modulate the cone of the 12 and muck up your good sound
hm... thats a valid concern
lets then swap the 12" for this 10"
10" Beyma mid
and make the rear volume behind it very small making use of the fact that it has high Fs and low Qts to bring up its resonance frequency to about 200hz ... then the compliance of air behind it should effectively prevent it from moving when the woofers try to modulate it
as a matter of fact we can put four of those 10s in there to make up for lost displacement ... they cabinetry would get a little more complicated but i can still see it ... again i can make a sketch if necessary
then this whole thing could be used up to about 500 hz and on top of it all we could mount another concave pyramid shaped concentric array out of lets say four 5" midranges and a 3" compression driver in the middle
it could all sum very nicely out in space. the two horns would have similar directivity and the crossover between the two horns (each of them a concentric array) would be low enough (500hz) to avoid lobing even with large C2C distance.
and then the well controlled directivity would extend down naturally below the range of the horn courtesy of the dipole ...
then just between the two horns a bullet supertweeter could be placed directly on the listening axis to fill 10khz - 50khz range
all in all it would be a 2+2 way + subwoofer + supertweeter ...
anybody wants to build this ? 🙂
i wonder if this will help with visualisation 🙂
