Digital noise on TPA3116 - I2S DAC - Raspberry Pi combo
Twerp
2013-12-23 5:05 pm
This is most likely a schoolboy error.
I've rigged up a little audio device that uses a Raspberry Pi and I2S DAC to feed into a TPA3116, but I'm getting awful digital noise through the amp output whenever the Raspberry Pi blinks an LED! The 19.5v supply is from a laptop switching PSU.
However, if I power the Pi/DAC with a battery power pack, everything sounds fine.
Have I wired this up wrong, or is the KIS-3R33S step-down board defective.
[IMGDEAD]http://s27.postimg.org/xkbisf4wj/schematic.png[/IMGDEAD]
Thanks in advance!
Twerp
2013-12-23 5:05 pm
How about grounding the 0V of the PSU?
Currently, there is no ground.
Also check what gains you have. How much signal gives full output and is it simply a case of reducing the gain on the amp by turning it's pot down?
What can I ground it to?
I'm using a digital volume control in the pi software. So the gain is 26db i think.
Thanks!
Sent from my X5pro using Tapatalk
Twerp
2013-12-23 5:05 pm
