Hi, very much a novice in this area. I have a Cary 303/200 CDP it has PMD200 hdcd and PCM1704 dac.
What I would like to know the digital domain VC goes from 0 to 64 on the readout, all sound great if it's used between say 56 to 64 on the VC.
The other day we used it on some Parrasound JC1's and Wilson Alexia's, because this setup is much more efficient we had to use the VC at 48 much lower and it sounded very flat (non dynamic and maybe rolled off at both ends).
Is there a some sort of bench test I could do that some give a reading/indication of at what reduced volume setting when "Bit Stripping" starts to happen, as we were all sure this was what was happening. As when I reduced the gain of it's output stage so the VC could be used at 60 all the goodness came back.
Cheers George
Cheers George
