Difficulty finding a replacement cap
I need to replace PSU caps in my 2 KD990 t/ts. They are Elna 2200uF/25V snap in 25mm w x 18mm d. There is a Polish guy on Ebay offering a complete set of electros for the KD990. I don't need a complete set just the PSU caps. I left a message on Ebay hoping he would response - no joy. I can see he's using 2700uF/50V which are the same size but I can't see the make. Can anyone help?
Any...... as in ANY decent 2200/25 cap with the same physical measure will do the job 100%.
Nothing exotic needed.Going up to 35 or 50 volt won´t hurt, if you can make them fit.
Absolutely right - nothing exotic needed at all. I got a replay from Przemyslaw - Nichicon LKS 3300uF/35V. That's the aof those Japanese d/d decks from the 70s/80s superb engineering coupled with well designed and executed electronics.
Reactions: FrankieS and Boydk
I did a quick look and that is an odd size. If there is more vertical space available, you could expand the search to taller caps. 18mm is pretty short. Even an extra 2mm to allow for a 20mm tall cap increased what I saw on digi.
I didn't get to see the latest posts, some sort of problem with diy server. However I got to order Nichicon 2200uF/50V snap in from a Polish company. It's the right size but as always postage isn't cheap.
Fingers xed this solves the problem with my Kenwood decks, continuity checks says it should.
Many thanks for all input.
Reactions: Boydk
