different idea- need help with blurrines
Hi everyone!
After seeing some awsome projectors here, I would like to get started myself.
I have a psone lcd that I would like to put to use as a projector. I would like to project the image directly from the lcd screen through a lens onto the wall without using a light other than the backlight of the lcd.
When using a magnifying glass lens to focus the image from the lcd to the wall, it produces a 40"ish image at about 7 feet away. The image is actually bright enough for me, but it is very blurry around the edges and not nearly as clear as I had hoped.
My suspission is that the lens is causing the blurines. Am I correct that a different lens will create a more clear image? If so, what kind would work best in this situation?
Thank you!
