dsavitsk said:Besides the fact that one is gapped, are there differences in the windings between parafeed and single feed transformers? Could you, in theory, restack the lams on a single feed transformer without a gaps and use it for parafeed duty, or vice versa?
I suppose you could, but not guarantee good performance. Changing the core to either open up or close a gap will cause the inductance to change enormously. This probably also alters the leakage inductance. As to what happens next, who knows? I wouldn't expect optimum performance either way.
I wasn't going to to do this with good transformers, but thought playing with some cheapies might prove interesting.
On that note, does anyone have a decent reference for learning to design and wind transformers? I've found a number of online references that give the basics, but something that has a few more nuts and bolts on doing some of the actual math involved and balancing the tradeoffs would be great.
Additionally, does anyone know a source for small quantities of laminations?
Radiotron Designers Handbook 4 Chapter 5 is the public domain place to start. Somewhat opaque.
dsavitsk said:On that note, does anyone have a decent reference for learning to design and wind transformers? I've found a number of online references that give the basics, but something that has a few more nuts and bolts on doing some of the actual math involved and balancing the tradeoffs would be great.
Try this site, and this software: http://www.turneraudio.com.au/education+diy.html
http://www.dissident-audio.com/OPT_da/Page.html
I have some EI lams and bobbins sitting around. Had to order 1k sets of the lams. I'd also like to know if anyone sells small quants.
Sheldon
- Tubes / Valves
- Differences in structure between parafeed ad gapped OPTs
