I think I get this, but I want to make sure. If I understand the data sheets correctly, these two plugins are identical, except that the 2.1 has an added option of mixing two outputs for a single sub if desired. But if that mixing option ("mono sub out") is not used, the unit operates exactly as the regular 2-way plugin. That would make the 2.1 plugin a bit more versatile but otherwise the same.
Do I have it right?
Edit: This refers to the "Advanced" versions.
Do I have it right?
