Perfect layer basically means that the windings of each successive layer fall in the grooves formed by the preceding layer.
Inductors Solen S14
Other than that they are air-cored inductors, although the form factor may also be computer optimised for Q.
w
Inductors Solen S14
w
No. If you want the absolute minimum DCR buy the perfect layer made by Solen or any other manufacturer claiming computer optimised. I don't know if any other manufacturer does make them, but there should be no difference if they do. Computer optimised is optimised. You can always compare DCRs vs. inductance.
w
w
