Hi guys!
New year is coming, greetings!
Got this denon PMA-700V amplifier for repair. The story goes like this. Owner connected speakers only to both R and L positive terminals, listened to music for a while and then brought the amp to me. Okey, 6/8 power transistors were burned. Also some 0.22R resistors and one driver transistor. As I was not able to get original power transistors [2SA1104/2SC2579] I replaced with more common analogues [2SB688/2SD718]. Of course, after replacing I turned on amp with light bulbs instead of one fuse on both channels. They burned. PNP [2SB688] were those that burned despite of using light bulbs. And somehow strange - only EC was shorted, BE and BC p-ns were OK. Okey, maybe some disbalance when using only one light bulb instead of on fuse or ESD for transistors or maybe defective themselves. Replaced again, put 2 light bulbs instead of fuses to one channel. Everything was working, practically no voltage drop on light bulb, managed to get the idle current in the proper range. After few more turning ons they were burned again (and more with driver transistors this time and R553 and R559 resistors). And this happens only during the turn on process.
Could this be related with transistors parameters? Seems like Vec breakdown voltage is too low, but it is the same for original PNPs, only original NPNs have more voltage compared to my analogues but they aren't which burn. Checked all around components including diodes, zeners, transistors - they are all good. Now I bought several pairs of [2SA1941/2SC5198] which withstand 140V for Vec(br). But maybe there is a thing I do not see here. Would be great if someone comes up with any idea!
Here is related schematic part:
Screenshot by Lightshot
Thanks in advance.
Thanks in advance.
