Does anyone have experience with the Decware DFR 8 modified Fostex Fe 206? I intend purchasing a set to install in large Open Baffles for use in a large room (30' x 16' x 10' )and would be particularly interested in hearing from others who have used this driver (or similar) in Open Baffles. Modelling the behaviour of OB's seems to be as dangerous an exercise as back horns!
If possible, I would like to avoide using baffle step correction and rely on room gain to compensate for LF losses. I have looked at the Decware forums, but would certainly appreciate any advice or suggestions from DIY Audio forum members. Integrating something this large into the lounge room and maintaining the WifeAcceptanceFactor will be the hardest bit!
Regards,
Glens
Regards,
Glens
