DC restorer
Can someone explain the DC restorer zener circuit and how to apply it? I have the same 'Base' model vintage amplifier used in Bob Carver's NEW design 'http://www.bobcarver.com/vta20s.asp' in the vintage amp he used a DC restorer zener circuit to stablize the voltage drop from tubes driven close to cut-off at high output demands. "This circuit 'zener is connected to the cathode bias resisterand fed back to the grids such that thegrid bias is held at a constant voltage (Carvers used 12volts) thereby restoringthe lost DC component of thedrive signal." His words.
kingfisher
  • High-Quality Brook Audio Amplifier With Automatic Bias Control.pdf
