DC current at the rating of the low pass inductor ratings, if large enough, could burn them out....but we are talking amps
DC current wound harm capacitors unless the applied voltage exceeds the voltage rating of the capacitors.
same issue for band pass inductors...it depends on the current rating of the inductors.
Speakerfritz you wrote in a ealier thread about a dc offset regulator, i have an adcom gfa585le with offset .016mv on right and 1.13v on left wouldthis work for me just until i can get these caps worked on? thanks ken
it would work. you can get the amp recapped, but it could be costly. email me your address. I have a simpler solution for you.
