I am building an amp with a LM1084 DC heater supply. It is feed by a 12.6V transformer with a center tap.
My main HV transformer has a 50V bias tap. If I put a diode on the 50V bias line and connect it to the CT of my filament transformer with this lift the DC output of my DC heaters ? Or would I do better to just use the normal method with a voltage divider off B+?
