I could do from .16 to 1.0 c feet for this 4"driver. Sealed and ported.
Can a TL enclosure could maximize mid bass, want to extract maximum bass with this driver. Which design could benefit me. Ahh if TL help please let me know dimensions and port length.
Any other idea welcome too.
For a driver with 4.5L Vas you'll gain little with any plain
box over 9L, its really designed for a small sealed box.
5 to 7 L well stuffed makes an ideal AV satellite.
Bigger vented alignments are all a bit wacky due to the
high Qts, and simply put you'd be better off with a bigger
driver, with higher Vas, lower Fs and lower Qts for any
vented box IMO.
TL or MLTL could work, but needs careful design.
rgds, sreten.
vented box IMO.
rgds, sreten.
Tell us more about your project (speakers, location).
You have the Dayton ND 105-4 already...
Can't you play with WinIsd or any other type of simulator?!
As sreten said that driver is very (port) frequency dependent (and int. volume) without a smooth frequency behavior. Very abrupt curve and nothing below a certain frequency.
