damping factor/stereo/bridged
I'm powering a DIY sub using a stereo/bridgeable amplifier. There won't be any power gained either way but I wanted to run this past you guys so I know how to wire this puppy up.
The driver is a 4 ohm, dual coil driver. The amplifier will deliver 500W to each coil running the left channel to one coil and the right channel to the other coil.
OR...
If I connect the coils in series (8 ohm load now) and bridge the amplifier, I will 1000W shared to both coils.
So my question is:
Is it better to run an amplifier bridged at 8 ohms for more damping factor and series two coils together (I'm guessing amplifier distortion goes up a little in bridged mode?) or run one coil on one channel and one coil on the other channel. Anybody hook up a sub this way? Will the tiny difference in output between two channels force the two coils to "fight" each other or something??
Thanks guys....
The amp is a Krell KAV-2250, 500WX2 into 4 ohms or 1000WX1 into 8 ohms in bridged mode.
The woofer I purchased is an Ascendant Audio Arsenal 15, 600W rms, 750W peak, Dual Voice coil, 4ohm per coil.
The box is a 9.6 cu ft sealed enclosure...thanks again for any advice.
I think your first option sounds great
This is just based on personal experience, not math: It makes more sense to me to keep the impedance low by using both 4 ohm VCs in parallel. Bridged amps/speakers combos sound "bloated" to me. I'll bet it sounds more responsive this way.
John
OK, first let's clear it up that damping factor in each case will be identical. When you bridge each amps output is in series with the load so you get half the damping factor. Also each side of the amp will see half the load impedance. So you see why it's just like each amp driving the channels individually.
However, there are big advantages of the bridged method. Firstly, the total current flowing in the PSU is half, which is nicer. Secondly, the ground is kept free of heavy speaker currents, which is nice again. Thirdly, the load on the PSU is shared in opposite polarity - it is balanced, this is nicer on the supply and is better for PSRR.
Go bridged.
Most amplifiers I have heard in bridged mode tend to sound more focused in the mid range and the bass tends to sound tighter and faster, subjective terms i know.
I suppose it really does depend on the amplifier, typically I am talking about Class A-B designs.
Is there a difference in the total voltage/current in bridge mode?
Amplifiers are not my strong point and it would be nice for somebody to fill in some gaps for me.
I recommend either to parallel both coils and drive them with a single channel or to connect them in series and drive them with two bridged channels. The reason is quite simple: Dual voice coil speakers are sensitive to unmatched drive of the voice coils, and this is likely to happen when two independent amplifiers or channels are employed.
