hey guys these daewoo subs on ebay look tops (apart from the daewoo logo all over them)
well ive never known this brand before....
SPECIFICATIONS:
* Max power = 1600 watts
* Aluminium diecast basket
* Classed as 12" (300mm)
* Wide (2") foam suspension
* Titanium aluminium centre cap (170mm)
* 2" voice coils
* Silver terminals
* 235oz magnet
* 2 x 4 ohm voice coils
* Mounting depth = 130mm
* Mounting hole diameter = 193mm
* Speaker wieght = approx 8.5kg (20lb's)
TECH STUFF:
* 89db SPDL (standard measurement - 1w 1m)
* "FS" (free air resonance) = 28hz
* "Qts" (total Q) = 0.5056
* "Qes" (electrical Q) = 0.5331
* "Qms" (mechanical Q) = 9.8241
* "Vas" (equivalent complience) = 60L
more info here:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=3292&item=5773840659&rd=1
is there some way of telling if these subs will perform well in either sealed or ported box?
ill be making a DIY box in my EB falcon in school(woodwork)
cheers
bentley
SPECIFICATIONS:
* 2" voice coils
* Silver terminals
* 235oz magnet
TECH STUFF:
more info here:
cheers
bentley
As Qts is quite high they will only be any good in a sealed box. They look good for the money. I wouldn't trust the power rating though as that is a heck of a lot of power to shove through a 2 inch voice coil. Half the RMS rating is probably more sensible but even that's a push IMO. Also excursion is not stated.
Max power is ussually rms-powerhandling x 4, so make it about 400 Wrms.
Still, without Xmax you don't know what power it can handle mechanically, so you would have to find out in practice.
Looking at magnetsize/thickness and Qts I would of course aspect it has a fairly large Xmax.
DAEWOO makes good cars and refigerators (and God knows what else
). If their speakers perform about the same, they won't be bad, but not special either.
Mvg Johan
Mvg Johan
Joined 2003
Joined 2003
I still think you could get something better for the price. I could be wrong though, I am not Australian and don't know how things are priced over there.
Just to clarify as I write this 1 AUD = 0.955865 CAD, and about the Pioneer deck, no it doesn't.
ummm i said retail....
thats not even from australia.
its just aussie ebay...
i know its like the same, but it just shows how espensive our other audio gear is in australia.
http://www.pioneeraus.com.au/car_entertainment/cdtuners/dehp1y/index.html
most other stores have it for the same price.
pioneers shittest single 10" is still $160
http://www.pioneeraus.com.au/car_entertainment/subwoofers/index.html
- Subwoofers
- daewoo?
