DAC7 extremly hot
I need help
I have DAC7 dual WM8741 WM8805 ver 1.1 .
dac is extremely heated , refrigerators are extremely hot, especially when the dac is in the case. 😱
Is anyone able to solve the problem of heating power ?
What operational amplifiers are the best choice ?
now I have opa0627 2x and 1x TL072
dac power supplyi s 9v + -14V
Run your opamps at a lower supply voltage, (+/-5V is probably OK) and feed in a lower voltage to the regulators. Don't change the opamps if you are already using OPA627, rather change the resistors and capacitors around the opamp for higher impedances.
I believe that those boards used a resistor to bias the op amps into class a. The problem is that the values are way too much. That will contribute to excess heat, especially in a closed case.
I would check that out before lowering the voltage, what is there for voltage now will be in line with what most op amps are made to work with, at least the ones you have.
The regulators do run warm also, and I wouldn't want that in a small, sealed case like that.
