This player has SAA7378(same as 7377/6) servo processor /decoder and TDA1311 Cont. Calibration DAC chip.
Now , I would like to know does TDA1311 use same input data as TDA 1543 , and if not where on this decoder can get I2S out for 1543 .
Is this possible?
TDA1311 and 1543 have same pinout exept pin 7 on 1543 which is ref. voltage out.
Thanks for every help
Is this possible?
Gasho said:This player has SAA7378(same as 7377/6) servo processor /decoder and TDA1311 Cont. Calibration DAC chip.
Is this possible?
No, TDA1311A has Japanese input format.
I can send you a datasheet if you want.
I have datasheet of all components that are in game , but what I like to know is can I use TDA1543 in NOS mode with that decoder?
The only thing that bother´s me it that decoder , and does he have out for 1543 , or can I connetc that DAC anywere before him . I think not , so I am limited to TDA1311
No, it won't work.Gasho said:I have datasheet of all components that are in game , but what I like to know is can I use TDA1543 in NOS mode with that decoder?
T![]()
Gasho said:1543A will work with that decoder ?
Does he have diferent input format?
Yes, TDA1543A has Japanese input format and wil work with your decoder!
Of course?????
Of course?????
Gasho said:Thanks , I bought 1543A for 1,2 euros , and it is works much better than TDA1311.
Offcourse i use passive I/V .
Of course?????
Gasho said:Becouse 1311 have internal I/V , there is no any kind of I/V circuit , just LP ilter and gain stage.
So simplest sistem to me is to use passive I/V , sometnig like Peter Daniel uses in his lats small dac project.
The TDA1543(A) does not have internal IV.
- Digital Source
- Cyrus dAD1 mod. help
