Even though the answer to this is probably straightforward, I could not find it with a little searching so I'll venture to ask:
Can a CT transformer of say, 300-0-300 @ 250mA be used to supply two separate (single-ended) powersupplies with [email protected] each? Does that work, and if so, should the CT be grounded or not? How to wire the 0? In this arrangement, the powersupplies probably run in counter-phase, would that be of any consequence when powering two channels of an amplifier with it?
I hope someone can enlighten me on this.
Thanks in advance.
Alexander
Thanks in advance.
Alexander
