I've been experimenting with good results with a Delta HD-8B lens from an 8" CRT projector. Seemed like a no brainer, seeing as the diagonal image on an 8" crt projector tube is going to be about 7". Turned out that coverage of the lens is quite adequate. The throw is a little short, but the f rating is probably well below f/2, as this lens is much brighter than an f/2.5 lens (Aero Ektar) that I was using before. I'm getting about a 96" diagonal image from the 7" Lilliput at about 8' from the screen. Should be no problem to get a 120" diagonal image in a typical living room. Getting even light across the screen was a little tricky, but I got it to work nicely with a condenser from Electronic Goldmine, two Staples fresnels stacked with grooves toward the panel and a third one closest to the panel with grooves back toward the lamp (a 400W MH). These fresnels are all stacked together behind the panel, about 1/4" away from it.
I had to buy three of these lenses and I only need one. I'm happy to offer the others to fellow Lilliput proj builders for my cost, $25 each, plus shipping for about 10lbs. The housings are a little bit dinged up, the front elements are very slightly scratched, and each lens is missing one of the lock nuts for the focusing adjusment. But they seem to project a clean image and the locking nuts are probably easily replaced with something from Ace Hardware. They are BIG, about 9.5" long and 6" diameter. If you are planning a tiny projector, crt projector lenses aren't the ticket. But if size is not an issue and brightness is, they seem to work very nicely with the 7" Lilliput and ought work great with a PSone LCD too. Forget using them with any panel bigger than 7", the lens will not cover.
