I can't spot a reference to XLS1500 on the Crown support website for discontinued amplifiers. Assuming it is a switchmode supply, it should be possible to have this checked for resetting or modification to a 240V supply. This could be expensive but otherwise, you are stuck with using a huge step-down transformer. Crown ought to able to assist there through local service agencies. Good luck.
