Will a crossover network (2-Way) work the same at line level as it does at speaker level?
I plan to do a Bi-Amp project with 2 low power amps but I want the amps to work in different audio frequency "Sections", per se. (Low/High) Full fidelity line level through a crossover, from the crossover to 2 separate amps. Use trimmers to level things out.
Would I need to put a load on the crossover(s) to duplicate the speakers normal load?
No you can't do that, it would need an 8 ohm load on each output - which would then kill your source.
The simplest (but fairly poor) option is to use a passive line level crossover. But you can make an active crossover pretty easily and cheaply.
What I'm trying to achieve..
I have 2 small stereo amps. (~3 watts/channel) I have 2 small speaker enclosures (2 way) that are full range. (80-20k) 3 watts each will drive them good enough for what I'm doing. The speakers..
Philips 314113000201 R TMM 2-Way LCD TV Speaker Module
I want to add some bottom end to them. I figure one amp for the full range and another amp for some bass. I'm limited for space so I figure an OB sub. The sub driver..
MCM Audio Select 8'' Dual Voice Coil Woofer | 55-1455 (551455) | MCM Audio Select
Should I just run both amps full range on the input and build a passive crossover for the sub instead of trying to filter the input to the amp that drives the sub?
Thanks in Advance!
Thanks in Advance!
An OB sub won't work without adding boost, due to the cancellation.
I'm not a fan of passive sub crossovers.
That driver will not work on OB. I've got one. The coil meets the backplate before you get anything useful.
Go sealed, or even ported.
Chris
Chris
And, moreover, OB/dipole solution suggests large spaces for the reason that...
1st you don't want first reflections from the walls/furniture being merged soon to direct sound
2nd the backwave is 100% error considering that front emission has PHASE and the rear is 180° rotated
I need to post a pic of the structure that I'm working with. It's a wife thing.. "Hay Hunny, can ya make a speaker outta this?" Appeasement is Powerful.. 😉
It's a multi level corner shelf. (Largest shelf on the bottom and the shelves get progressively smaller towards the top) It's made to sit tight into a corner. The bottom shelf is what I wanted to use for the sub area..
I don't believe 6 watts max is going to make it hit the back plate.. LOL.. Maybe a sealed triangle shape box with a bunch of stuffing? ~.15-.2 sq. ft.?
V-e-r-y clever. 🙂It's a multi level corner shelf. (Largest shelf on the bottom and the shelves get progressively smaller towards the top) It's made to sit tight into a corner. The bottom shelf is what I wanted to use for the sub area.
Just make sure her trinkets don't vibrate off or move around.
So.. How about 2-3 mH. between the one amp and the woofer with the woofer in an enclosure? I could possibly use a stereo pot before the other amp that feeds the upper speakers to level things out somewhat. Sound like a plan?
You won't get much from that driver OB, so yep, sealed with a lot of stuffing is an option.
I'd recommend you try OB, but be prepared to change it - its good to hear these things yourself.
Chris
PS - try OB, but with a pile of stuffing behind the driver.
- General Interest
- Everything Else
- Crossover Question
