Hi All,
I have just found some Jbl MR25 speakers,one with a missing woofer.I had some Skytronic 130mm woofers sitting around.After fitting them found the not very loud and no bass.Me thinks with the Jbl woofers being 4.6 ohms and the new speakers 8 ohms ,something is out of balance.Can anyone give some help designing a new crossover? Thanks Don
New woofers
Surplustronics - Wide Range Kevlar 5.25" 100W RMS
New woofers
In general, successful driver replacement requires a careful match of Fs, Qts, Re and efficiency. Anything else is a complete redesign, with a measuring mike, simulation software and all new crossover components.
I have 4 successful speakers designs and I would not attempt what you are doing.
HTH
Doug
HTH
Doug
D'oh!-Thanks anyway.
I wasnt looking something that flash. just a little more bass than what im getting.thanks Don
Hey, Kiwi.
You can not compare the two mid/woofers (different SPL/different impedance/different specs), with out any more data/specs available (no specs).
Now, what you have is impedance of Re=7Ω on the new woofer (902402).
The JBL (76431) is Re=4,6Ω. There is an impedance mismatch that will bring your low frequencies down for a couple of dB's (1). Plus, your JBL speaker is 87 dB SPL... and your new woofer (902402) is 84,8 dB SPL (2). All together, less output from nº1 plus less output from nº2. You are engineering a nightmare. Good luck here
