I do not know if this will help, but I have a Coustic Power Logic AMP-160u & it's fuse is rated at 15 amps according to the manual, & it is bridgeable.
I have a few different Coustic amplifiers, mostly older ones that I have repaired & they perform well in my opinion. I have the AMP-160u, AMP-260u, AMP-190, AMP-260, AMP-360 & a 600SE, to me they all work very well, though some are very old & have been repaired, they sound great! The only one I have not heard yet is the AMP-190 as when I ordered parts for it I was sent the wrong ones & have not ordered the correct ones yet, hopefully sooner or later I will get the parts for it, but I imagine it sounds about the same as the AMP-160u & AMP-260. The amps have been in boxes with the rest of my collection for a while now, so I hope I have all of the model numbers on them right.
You could check Coustic's website in there CLASSIC section as they have a lot of old manuals there, you may find what your looking for. Anyway, I hope this info helps!
Here are some of the specs for the Power Logic AMP-160u: (might be similar to your AMP-160)
POWER SOURCE- 14.4V
Rated Power In Stereo Mode (0.09% THD):
35W x 2 @ 4 Ohms
50W x 2 @ 2 Ohms
Rated Power In Bridged Mono Mode (0.2% THD): 100W x 1 @ 4 Ohms
Sound to Noise Ratio: 95 dB
Fuse Rating (Ampere): 15A
