Working on this Coustic 600se, it keeps going in and out of protect.
There is -rail voltage on the speaker leads of the right and left. I measure the +/- 15 volt supplies and they appear to be coming up fine.
There are no apparent shorts in the TIP 35C/36C out puts and predrivers.
I know this is an odd amp design with alternating outputs. I used an external supply for the +/-15 volts, to power all the op amps. It has clean audio to the muting transistors. and there is no DC offset.
Any thoughts?
Any thoughts?
