coupling cap size substitution
I have an SSE running nicely. I have a pair of nice Russian k40 coupling caps that I would like to install instead of the existing units. My replacements are 0.1uF vs. the spec'd 0.22. Working against a 220k output tube grid resistor, it would seem not to make too big a difference. 7HZ vs. the spec'd 3HZ 3 db point.
Am I missing anything?
Thanks.
