Counterpoint SA-3.1 Rebuild
Hi, I am doing a complete rebuild on my Counterpoin SA-3.1 and had a question. I was able to download a schematic for the 3.1 from Audio-Circuit.dk and if shows using 1uf/200v P.P caps for the phono sections as well as the line stage output coupling caps C18,20,118,120. The originals caps are 3uf Wonder caps, also the 2 watt plate load resistors for the line stage show 13k on the schematic, the original are 22k. All other values are the same. I have never been great with the math (lazy I guess). Will using 1uf caps or the 13k resistors cause a problem.
Thanks in advance, Ron
