Hi Folks
I'm building a multi channel amp 3 x TPA3255 amps expandable to 4 boards (6 to 8) channels. I got a 2kW SMPS from connex electronics and put 1 channel relay for the remote 12v trigger from ARV.
This is the relay https://www.amazon.com/gp/product/B00LW15D1M/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
Wired the EMI Filter to PS and relay as follows:
Live to PS Direct Wire Connection
Earth to PS Direct Wire Connection
Neutral > Relay > PS
The SMPS keeps powering up regardless so switched the relay to live wire, well same things happened. Should I have a two channel relay to isolate both Live and Neutral? Any recommendation on which relay to use?
There is also a pin header that is not described online in the attached picture, I now -A and +A are auxiliary power but what about the rest of pins. Is there a way I can put the PS in standby?
I tried email connex electronics several times but I did get any answer, maybe they are affected by the situation in HK.
Can someone help please? Thanks
