I'm going to start singing with the piano. The bench is 30' from the PV8 mixer. Will a WBH53h shure headset condensor mike pick up hum & RF noise with a TA4F-XLR-f 4' adapter cable and a 25' XLR f to m cable? The PV8 mixer has phantom power.
My voice is rather soft, so I favor the cardiode pattern to not pick up the piano through the organ speakers. My voice needs reinforcement through the organ speakers The hall is 35'x60'x14'. I won't be moving around so I don't want a radio link system. Also no radio saves $700.
I realize Billy Joel uses an SM58 on a boom, but I bob my head a bit when I'm playing 6 octave material. His voice is probably louder than mine, too.
AKG C555 headset mike is also possible, cardiode condensor mini XLR connector.
Also the main podium sound system started going thwick thwick thwick 2 weeks ago and a backup voice system might be useful if the radio base stations, mixer, or main PA need all new electrolytic capacitors. They are ~10 years old. I reseated the base station-mixer pin headers & the noise stopped, but that is no guarentee of success. November is capacitor failure month.
The organ amps were totally and PV8 P.S. were re-e-capped by me, should be good for 25 more years. The organ speakers are hifi 2 way KLH23's. (The Allen speaker's surrounds discintegrated). I pulled 2 Allen tone generator RCA inputs to the two S100 amps, diverted them to the mixer 2' away, then 2 RCA cables run the mixed mains back to the S100 amp inputs. Voice input should be mixed in at fixed volume. Speakers are about at same distance from the front into the room as the piano, but the piano is way off to the left and the speakers are 12' from the walls and 3' off the ground facing the audience.
When I first installed a 12' RCA cable from RA-88a mixer to ST120 amp, at home nearby, I was picking up AM sports talk radio. I had to up the input cap to ground from 33 pf to 68 pf. The PV8 input capacitors were surface mount and not marked, I don't know what value they were. So there is RF AM bamd noise around here, and the main PA at the church has 2 radio link business band mikes.
Thanks for listening.
