Hello,
I was browsing through the Marchand Electronics page, and I stumbled on this... definitely looks like a high-power transconductance amplifier, and Marchand is an excellent company in regards to electronics.
$950
http://www.marchandelec.com/cl54.html
Would be fun to use with subwoofers as would bypass the issue of thermal compression and other non-linearities...
cheers,
-tal
$950
cheers,
-tal
Actually CCS amp add other nonlinearities, overshoot duu to no damping... see my posttaloyd said:Hello,
cheers,
-tal
http://www.diyaudio.com/forums/showthread.php?s=&threadid=60895&perpage=10&pagenumber=63
tade said:what is transconductance?
constant current source rather than constant voltage
Constant current source . . . ? ? ?
My understanding is . . .
Transconductance amplifier (current amplifier) means that output current is proportional to input voltage while voltage amplifier means that output voltage is proportional to input voltage . . .
jH
Hmm . . .
I do not know why I can't connect . . .
Probably u could do . . .
www.firstwatt.com
Full info there . . .
jH
jH
Your understanding is correct... and it is called a ccs for that reason... The important thing I would point out to you however is that these amps have little or no damping and damping is what stops or reverses a speaker according to the signal put into it to prevent overshooting...
I did a couple of rather crude writeups on this if you woud like to see them, just beware of the elitest hype...
If you say "current source", then you are right . . .
If you say "constant current source", I'm confused . . .
Probably, you are confused . . .
Output impedamce is, yes, high . . .
jH
Re: Re: commercial high-power transconductance amplifier!
This is only true if the speaker unit has inadequate internal damping -- which describes most speakers available. Fortunately there are some very good drivers with adequate mechanical damping that work best with CCS amps.
dave
rnrss said:Actually CCS amp add other nonlinearities, overshoot duu to no damping...
dave
I would request that we don't turn this into another discussion of Damping Factor. I think everyone has had his or her say on the subject...
- Subwoofers
- commercial high-power transconductance amplifier!
