Question for the gurus here:
On the board below, I have clocks coming in from the left and being distributed to two ICs. The pads you see are 50R resistors. SDATA, LRCK, and BCK are all relatively low-frequency clocks, but MCK is running at 24.576MHz.
My question is about how best to route MCK. The desired path is indicated by the brown line, and I could push it through almost as depicted, but I am concerned about crosstalk.
Other options would be jumpering MCK over this block via the topside, or under the board.
As for routing on the bottom layer, I am concerned about routing under clock lines. Routing completely around these blocks would create very long traces, which is not an option.
How would you route this signal?
