John - There are a couple of possibilities for your ESL drive. Please contact me directly and we can discuss.
Slew rate is kind of an iffy spec where switching amplifiers are concerned. The step response of our driver products (TA3020, TA010x) is around 10kV/uSec. When used with typical output MOSFETs, the overall system is in the 3kV/usec range. If those seem like big numbers, remember that on/off time is critical to the basic operation of a switching amplifier. Comparing those sort of numbers to linear amplifier slew rates is not all that informative, but no, you will not be slew rate limited with our topology.
BeanZ - There are a number of things which will impact the value of Rnew (as referenced in the app note) when trying to settle in at 650kHz. MOSFET selection, load, rail voltage and circuit layout will all impact the final value of Rnew. The 500-1k range is an estimate and will cover 90% of the cases, but not all. As long as your final Rnew value puts you somewhere in the 600-700kHz range at idle (and at idle temperature), then you're fine.
Tuning the Zobel to 80kHz (our primary LC filter) is correct, as you noted. It's only function is to reduce the peaking in the primary LC filter under no-load conditions.
The TA3020 is in full production at this time.
Regards,
Scott Bobo
Tripath Technology
http://www.tripath.com
