Class D is HighEnd?
ghemink said:
If you have heard one, what was your impression? Gertjan
the answer to your question is a decidedly yes. I have heard quite a few digital amps lately, T/SuperT, HK DPR1K, UCD, Panasonic XR, and a few in my computers/pda/cell phones, to name a few. not to mention a NuForce Ref9.
Sound quality wise, they are on par with a decent SS amp, and I would consider them a notch below my HK630 but in all honesty I would be hard pressed to tell them apart in a DBT.
In my view, they are grossly overhyped, in terms of sound quality.
That is not to say that they are bad amps. They are just indistinguishable from a good analog amp.
Pafi said:
This: "The most power that will be wasted below 1W output will clearly be less than a watt."
Yes, you're right Pafi, that is not a correct statement. I don't know what I was thinking about.
From the graph at 1.125W output the class d amp is about 25% efficient. So it's input power would be 4.5W and the other 3.375W would be wasted as heat.
The class ab amp is about 7% efficient. That means it's input power would be about 16W, so 14.875W would be wasted as heat.
Below that output power I can't easily see what the efficiency would be but it's pretty close between the two.
samsagaz said:
Hey guys, i want to upgrade my HT, its just an 5.1 channels. I want to sold the Receiver and want to use dedicated amps for each channel, i want to get at least 200Watts per channel. i really want to know if buiding and classD amp will get nice sound, (comparable with comercial ones like Rotel RMB-1095)?
I want to drive a pair of Polk LSI Series Speakers.
The poor guy (samsagaz) started this thread with a simple question (see above). Most of the thread now comes down to in my opinion irrellevant quarreling about mA`s quiescent current. He just wanted to know whether a 200W Class D will give a nice sound. Personally I think it will blow away the above mentioned conventional amp, however, anybody heard that Rotel AMP? So I would say go for Class D and you won`t regret it.
Best regards
Gertjan
C'mon, you know you can't have a "class d highend??" thread without all kinds of fighting 🙂
I can also highly recommend the UcD180 modules. They're about as bulletproof as it gets and absolutely qualify as high end in my book.
I don't think you'd regret em one bit. It is a good idea to get a few and experiment with for awhile before planning your entire system though.
