I can not find an answer to this simple question :
I build the simplest class A stage with a 2N3055, speaker as load. Resistor divider for bias. How does the input signal ( very small -mV ? ) "overpower"
the bias ? Say output impedance of previous stage is 47k and the bias resistors
are low value - hundreds of ohms. AND, what if I lift the base voltage in relation to the ground by adding an emiter resistor ?
Sorry for such stupid question - I am a mechanical engineer.
In that circuit the input signal would not "overpower" the bias. To get useful amplification you need low source impedance and high bias impedance.elderjoe said:How does the input signal ( very small -mV ? ) "overpower"
You would have to draw out what have configured but I think what you are getting at is this...
The bias isn't 'overpowered' by the input signal, but rather it is modulated by it. The effect of that is to alter the base current flowing in the transistor, either adding to it, or decreasing it depending on which way the signal is going. That change is amplified by the gain of the transistor and allows you to get a usable current flow in the collector of the transistor, which in turn drives the speaker.
Adding an emitter resistor 'degenerates' the transistor stage and does a couple of things. It makes the bias setting a bit more stable with regard to temperature change and also differences in individual transistors, and it also lower the gain of the stage.
Draw out what you have and we can take a look. For instance, I assume you have AC coupled both the speaker and the input source to the transistor.
