Hi Folks,
About to resurrect a Clarke and Smith Amplifier chassis which was used in a 1960s "Talking Book" outfit. These were used by the Institute for the Blind to supply subscribers with audible newspapers/books etc. I don't have the unit, just the amp.
Basically a tape player, magnetic pickup, first/second stage, volume/tone control and an EL84 used Single-Ended. EZ80 rectified power supply.
I thought I'd ask before I delve into it, anyone have a circuit diagram for these units handy?
Would save a bit of head-scratching time... 🙂
Alec
Alec
It's only an amplifier and as it is from the 50s no information.
As I say, an amplifier is an amplifier so no problem repairing it.
Ferrograph World
Ferrograph World
Hi Folks,
I can't believe it's been so long but never mind..... The dark evenings are now here and it's back to the indoor projects in the evenings!
Photos of the amp:
Circuit Diagram found recently on the Net, accurate and represents the unit I have here:
It is missing the input transformer and the tape unit drive motor.
What is there currently: a mylar 0.1uF capacitor on the input to the first stage magnetic pickup preamp, this would do I expect for a Phono input?
What I would propose to do is:
Alec.
Photos of the amp:
- To go through the circuit and replace the aged electrolytics, the small Mullard Mustards look to be in good condition.
- Mount the unit within a replacement housing to smarten it up and add a bit more protection/electrical safety.
- Add a switch to the HT Line after the choke for warm-up purposes.
- Add an additional input to the second stage preamp, probably at the intersection of C7 and the 1M RV1 to function as a line-level/CD Input.
Alec.
The gain structure is set up for the mV. signal level a tape head produces. A single 12AX7/ECC83 section is enough, when a CDP is the signal source.
The B+ supply already starts "softly", as the EZ80 is indirectly heated. No switch is necessary.
If music bandwidth is to be had, the O/P trafo requires upgrading. Also, NFB of some kind is needed in order for the damping factor to be satisfactory.
