CK1006 ignition voltage?
Hi guys,
Have you tried using CK1006 gas rectifier?
I've just made a test circuit with CK1006 where the plate voltage is 460Vac and the filament voltage is 1.7Vac supplied to the CK1006 rectifier. It is configured as full-wave rectification with 1st capacitor of 0.1uf followed by a 10H choke and a 20uf capacitor. The circuit connected to it is supposed to draw ~130mA.
Nothing happened when it is turned-on. The gas was not ignited. Measurement at the plate and filament for CK1006 showed the correct value. Filament lights up. '
Checking the datasheet for CK1006 specifies that for capacitor input full wave rectification, it needs 420V per plate. Does it mean that I need 820Vac supplied to the plate? This does not make sense too.
http://www.mif.pg.gda.pl/homepages/frank/sheets/138/c/CK1006.pdf
Datasheet states typical operation at 800Vac capacitor input with 550Vdc output. That calculates to 800Vct (400Vac per plate). Am I reading it wrong?
Any advice is appreciated.
Thanks!
Are you using a Graetz hybrid bridge or is the transformer 460VCT? (230V-0-230V) The voltage on the plate should be 420V minimum, a hybrid bridge with any 460V transformer will meet this criteria, a 460VCT transformer obviously will not if the center tap is grounded.
Can you post a simple schematic?
Nothing happened when it is turned-on. Checking the datasheet for CK1006 specifies that for capacitor input full wave rectification, it needs 420V per plate. Does it mean that I need 820Vac supplied to the plate?
You need a minimum of 420V peak. Do you have a secondary with a center tap, and is it connected to ground?
