Hi, I bought a non-working class D, JBL ARC SUB10 to repair. After replacing some capacitors and a resistor it works now but I noticed another problem. Some glue from a hot glue gun that was covering a resistor had liquified from that resistor getting hot. Not hot enough to burn out the resistor, but enough to melt the glue around it. This happened before the capacitors burned out and when I power the amp it still heats up. It is the resistor R19 circled in red on the schematic. It is part of the circuit circled in green. At first I thought the green circuit was some sort of voltage regulator, but then I saw it was controlled by the audio signal which I thought was weird. Looking into it more I figured out the LED DRIVE was a 2 color LED that changed from red to green when I audio signal was fed through the amp and the circuit was some sort of auto 'power on' since there is no power switch.
This circuit confuses me. Could someone explain in simple terms how this circuit automatically turns the amp on and off?
And since this sub will be turned on and off by the power strip it will be plugged into, this circuit is not really necessary. Could I remove resistors R19, R20, and R21 and use it that way (always on unless unplugged)?
Scott
Scott
