Years ago I built some Dalines from (I think) a Wireless World design.
Then I designed a current-dumping amplifier.
Now I want to build the following:
SoundBlab Transmission Lines (Tang Band driver) with Blameless Amp (D Self)
Is that going to give me good sound? I don't want the best, but I do want good.
And what wireless streaming input device would you recommend?
Thanks for any help!
Welcome to the forum.
On 1st look, looks to be a design to stay away from (looks like it uses Classic Design methodology, and not designed using modern TL modelers (the big clue is no driver offset). And with so many really good. proven modern TL designs for FR drivers, why settle for a compromised design. Look for Pensils, Taaqs, stuff by Scott Lindgren, Paul Kitt, others.
While superb work in theoretical aspects falls down with the subtleties.
Harmonic Convergence: the Effect of Component Tweaking | Stereophile.com
Editorial w test measures that show where Self does not go far enuff.
dave
SoundBlab Transmission Lines (Tang Band driver) ...
D Self
dave
