Can you use 18650 batteries to power a small amplifying board e.g. www.st.com/web/en/resource/technical/document/.../CD00211320.pd
Say the batteries put out 4V at upto 30Amps will an amp just sort of take what it needs or will it ruin the amp cause the battery puts out too many amps
nope, running an amplifier on battery power is averry good solution.
it will draw current as it needs, its perfectly fine.
i consider battery power to be a lot cleaner than main's power.
it does not have any mains hummmm at all.
