salute folks
what is the best way to calculate values for a choke ?
i my design i have a 375vdc after the resitor.
c,r,c 385v+ resistor+ 375 on the out.
it feeds 3 6922 tubes.
i want to replace resistor with a choke.
thank you
richt🙁
thank you
richt🙁
richt,
Download this free software and design any supply you want. No spam and it is easy to use.
http://www.duncanamps.com/psud2/
After reading your post it is easier than that. Whatever the value of the resistor make sure the choke has the same resistance. Hammond Manufacturing states the resistance of all of their chokes. It should also be rated at least at the current that the tubes are using or more, but no need to go more than 50% more. Beyond that get the most henries you can. If the choke is not high enough in resistance you can add enough regular resistance to bring it up. Actually I don't think additional resistance is needed as the circuit should work fine with 375 or 385 volts. The only problem would be if the choke resistance is greater than the resistor it replaces which is probably not the case.
thanks
i am trying to download the program to see how it works.
i have the hammond choke tables but the selection is huge!
thanks
richt
thanks
richt
thanks for your time !
i have in my homemade pre a 500 ohm resistor
for the reg. c,r,c.
total consuption is average 40ma.
thanks
for the reg. c,r,c.
thanks
A 500 ohm resistor at 40ma. will drop 20 volts. Your circuit is only drawing 20ma. if it is dropping from 385 to 375 volts.
The Hammond 157G is 30hy at 40ma. 595 ohms. Should work well but your numbers seem a bit off. Look at it again. Let me know if your current draw is lower or the voltage drop is more than 10 V.
The 158L is 15hy at 75ma. and 411 ohms, another good pick.
thanks again!!!!!!!!!!!!!!!!!!😎
i measured the ma & it is around 33ma (i am measuringwith
the resistor in series with the probes.
i bought this counterpoint pre on ebay & i like simples design.
i rip off the transistor regulator & installed a mosfet.
big improvment!
then i decided to try hexfred diodes & sounds awfull !
later i throw away the tiny power supply transformer
& installed a hammond & 5u4 tube rect and my head blew off !
silicone diodes for pre are not good! but are necesarly
for tube amps for transients.
thanks
for your time!🙂
big improvment!
thanks
for your time!🙂
could you post the schematic for the mosfet regulator? so on your opinion which is better for B+ tube regulator or diodes ? could u state the difference also
thanks
thanks
Being sceptical of this myself until I tried it, I am now an ardent convert. Try a choke input supply too for even better results.richt said:later i throw away the tiny power supply transformer
Silicon diodes are not good in the power supplies of any amps. The only bonus you get in a <i>properly designed</i> tube amp PSU by using silicon diodes, is a lot of switching hash. My power amp suffers no lack in dynamics and it is tube rectified CLC.silicone diodes for pre are not good! but are necesarly
HENRY VIII
Hi Richt,
What Counterpoint pre do you have?
Putting 375 VDC on the plate of a 6922 is way too high BTW.
You could introduce a good tube regulator on a pro stage basis while you're at it.
That will leave you with your head blown off for sure.😀
Cheers,🙂
Hi Richt,
Cheers,🙂
salute to everyone !
an original counterpoint sa3.1 sounds awfully bad & harshy !
first i removed all the the trasistor regulation & all mr.
elliot design ! (i like this pre because it is easy to upgrade &
performs really well).
i installed a mosfet regulating from 375 to 250 volts.
the sound became less harshy & more musical.
still i notice a small saturation on the top end & i found thaT
the 6922 were driven too high on ma. ( plate with 22k resistor
and the pcb completly dark on that area)
i raised the resistors to 100k and the sweetnes of the tube came alive ! (3ma per plate)
now i have a tube preamp!
on another site i heard people glorifying the hexfreds, i tried,
but money was wasted ! abrassive sound overall.
one day i came with the idea of replacing the transformer with
that o ne from mike elliot website (plitron toroidal)
costed me a lot of money and the preamp was running a lot hotter (filament reg) & the sound was awfully bad.
i was so angry that i sold on ebay for 50 bucks and i called
mike elliot to told him where are his ears located?
now i bought a hammond 10vac 4 amp for filament & another
hammond for a 5u4 (filament winding was center tapped so b+
was a lot cleaner that taking out the b+ brom one of the filaments pin.
now that was another preamp !!!!!!!!!!!!!!!1
really creamy & smooth !, very extensive on both ends,
natural floating sound,no coloration at all !
i consider that these preamps are a little gem for the price &
simple designs.
now the choke is on its way.
thanks you people
richt
simple designs.
thanks you people
richt
CONTRAPUNKT
Hi Richt,
My second tube pre was an SA3.
Didn't sound that bad at all,a bit too noisy and microphonic as hell.
Naturally you heard them flaming Wondercaps' colouration as well.Chocolate/caramel flavour.
I think the main difference with the bigger brother the SA5 was that Mike put in some sort of valve regulation (5661 I think it was).
What you can do too is replace the 100K resistor whith a 3mA constant current diode.
That really tightens the bass.
Give it a shot,😉
Hi Richt,
Give it a shot,😉
Re: CONTRAPUNKT
Glad you're having fun with your revamped CP.
I agree with Frank about the CCS. Try it, and I would suggest you leave it in circuit for a few days, because they can have a large affect on the perceived distortion. When the distortion is gone, and you're used to it being there, it sounds strange until you get used to it. When I first got my bass horns they sounded weird and a little weak, even though they measured well and went deeper, because there was so little distortion.
I'd also try running the tubes at much higher currents, like 6-12mA, depending on the stage and the amount of swing required. 6DJ8/6922's sound <i>much, much</i> better when run hot. All the one's I'm currently using/playing with are 9mA per section or more.
Cheers
Hi Richt,fdegrove said:What you can do too is replace the 100K resistor whith a 3mA constant current diode.
Give it a shot,😉
Cheers
HOT 69XXX
Hi Richt,
3mA for a phono stage would do.
If you're only using this as a line preamp then I agree with what Brett says.
Brett,
Funny how we get used to colourations.
Cheers,😉
Hi Richt,
I'd also try running the tubes at much higher currents, like 6-12mA, depending on the stage and the amount of swing required. 6DJ8/6922's sound much, much better when run hot.
Brett,
Cheers,😉
salute guys !
i notice that applying excessive current to a tube, tends to
sound harshy (on a extreme case as m. elliot did).
a ccs is a circuit or a component (diode) ??
i will try the choke this week and i let you know folks.
the cathode is tied to ground directly in this case.
(usually a 1 to 4 k omh resistor is used)
i am glad to answer any questions.
thanks
richt
p.s. some new pre are using the 6c33.
if anyone have a feedback from this tube?
it is pin by pin with the 6922🙂
thanks
richt
Richt,richt said:p.s. some new pre are using the 6c33.
The 6C33 is a power tube used in the BAT power amps and some OTLs etc.
Could you be meaning the 6N1P? That is compatible with the 6922 series in many but not all instances. The filament current is higher and the u is lower. Many people like this tube. I have some but have only played with them breifly, so no firm comment on the sonics.
KONTRAPUNKT II
Hi Richt,
CCS:
Constant Current Source,this can be a single component such as a Constant Current Diode,a fet made to behave like that or in some more complex situations a circuit made for that particular application such as Mr.Pimms as described on his website and discussed in this tube section.
In which case your tube has no negative gridvoltage and will go into positive gridbias when presented with voltages of over 0 VAC.
This 6922 can take a lot but 2 VRMS from a CD player is way too much.
A cathode resistor in the 500R range would be a good start to try out.
Unless this negative voltage is derived from the PSU which could be the case.
I remember Mike Elliot did that quit often in his designs so if you have a VOM you can check this.
In the SA 3 I think he used high value grid resistors (~10M) but check it anyway.
This is a big voltage regulator tube.You can build an amp with just one of them.
People building preamps with that are $$#@*^ ,you know what I mean.
And no it is not pin to pin compatible with a 6922.It is about 20 times as big.
Are you still running your circuit from the original Counterpoint board??
What section are we discussing here?Line ? Phono ?
Sorry if I spoil the fun but if you want to build a decent circuit we're going to need a lot more information.
Don't loose any sleep over it we'll work it out,🙂
Brett,
Sorry,I didn't notice you replied to this already.
BTW,I've seen linestages whith 6C33C,so this could be what Richt means.
What's going to be next I hear you mutter??😉
Cheers folk,🙂
Hi Richt,
CCS:
Brett,
Cheers folk,🙂
Re: KONTRAPUNKT II
I was looking at using the 6C19 as a linestage recently. Run it at lowish voltage, say Va=90V B+= 130V, 40mA/tube differential with a CCS as each tube's load. Output Z would only be a few hundred ohms and it should have no trouble driving just about anything with no headroom issues. With a near horizontal loadline it would be very linear, and the low u would make it ideal for CD based linestages. Tubes are only a couple of dollars each and 6.3W of heater should help it sound powerful.
Whaddya reckon?
Cheers
Brett
Frank,fdegrove said:BTW,I've seen linestages whith 6C33C,so this could be what Richt means.
Whaddya reckon?
Cheers
Brett
Whaddya reckon?
Hey Brett,
Have been thinking along the same lines,that valve is the perfect candidate for the job.
Have you ever seen the TFK ED8000?
Make a very good well regulated shunt reg (you know how I would do that) PSU for it and you can drive even the silliest length of interconnect with it.
Hmmm,you can even use an 6C19P as a series pass in that reg there...
I'm all for it and it makes perfect sense to me.
Cheers,😉
P.S. Fred has written up a very good article on PSU regulators in the Digital section.
Some people there are still struggling,I may drop a bomb or two there.😀
Hey Brett,
Cheers,😉
- Analogue Source
- choke transformer question
