Does anybody want this item? It should fit your standard LM3886 or OPA549 amp, etc.
was planning to use lexan/plexi over the chip to "see the guts"
It has 2 holes that pass thru and 1 is drilled for a XLR panel mount plug. the other was going to be a speakon plug or 1/4 jack for speaker out. the slot on the front was to pass the power supply wires thru. 2 holes not shown in the pics are drilled for power supply caps to be "dropped into" to help with p2p wiring. the tapped holes are not too great, but im sure you can make this into a great little amp!
if you want them just pay shipping, unless you want to trade/give me some of your left overs then i'll ship to you free
Stevehttp://www.diyaudio.com/forums/showthread.php?postid=1031010#post1031010
